#1 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
did you use a 7/16 drill bit to slot the struts? I'm assuming you used the top hole?
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
#2 | |
0-60 in slow
A drill bit would make the job take quite a bit more time FYI since most of the shocks are thick DOM. |
#3 | |
0-60 in slow
The die grinder was pneumatic but a dremel works as well its just slower. I wouldn't use a drill only because it'll take a really long time.
If you look at his picture the only thing you actually need is the silver piece it pops right off the mount that silver piece is the actual bearing the black piece is the spring support which isn't be needed. |
Ok so take the "silver piece" press it into the red top plate provided by megan put the stock black donut on and install? The thing confusing me was if we had to reuse the top oem black springplate or not
0-60 in slow
yes like this
| Megan Racing header install and review with pics. | Herbicidal | Performance Modifications | 6 | 09-03-2009 08:40 AM |
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 05:26 PM |
| Megan coilover fitment problem | YaYa1320 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-06-2009 08:01 PM |
| Megan Coilover install DIY | kapo | DIY / Maintenance / Service | 5 | 09-24-2007 07:20 PM |
| Megan or Tein suspension | elmercurrie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 43 | 05-31-2007 09:41 PM |
