![]() Drives: 2009 Yaris Sedan 5-Speed Join Date: Apr 2009
If you are rev'n above 3k consistently while shifting you are being hard on the clutch. It isn't a sports car. It can handle it without issue, but doing it repeatedly will cause the smell. I have done it.
On another note, these are Variable-Valve-Timing (VVT) engines, so the gain to rev high isn't like it was before VVT. My old Tercel use to get faster if I rev'd up to redline, but the Yaris isn't quite the same. I do on occasion go to redline, but that is simply because I need both hands on the wheel for the moment during speed runs. |
#2 | ||
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
I think you might have misunderstood what I was saying. My normal shift point is around 2k to 2500. What has been happening is that I would attempt to shift normally, and drive normally thereafter **not high revvs**, but the engine would rev higher than normal with the car barely moving. Almost as if the clutch is engaged without me touching the pedal. I guess another way to put it is that the car lost its "pep". Quote:
As far as any vibrations, I have not experienced that.
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
Ah. I was confused and misunderstood.
I will say out off all manual transmissions I have owned. The clutch in the Yaris gives me the most grief. I feel I have to rev the engine more than needed to ensure it won't die. That combine with the friction point being tiny with not a lot of feedback. |
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 04:59 AM |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 08:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 06:20 PM |
| Worn or bad clutch? | Tonavi | DIY / Maintenance / Service | 6 | 04-27-2009 10:11 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 12:34 PM |
