Old 10-04-2012, 02:11 PM   #5
bronsin
bronsin's Avatar
Your clutch is bad if the engine and transmission vibrate a lot when letting the clutch up. Almost no matter how smooth you try to be, there will be vibration.
Another bad clutch symptom is motoring along in gear and when you punch the gas pedal, the engine revs up but the car doesnt go any faster.
The defroster doesnt have anything to do with how well or bad the clutch works.
That burnt smell is another sign your clutch isnt what is should be.
Good luck and tell us what happens!
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Worn or bad clutch? Tonavi DIY / Maintenance / Service 6 04-27-2009 09:11 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
