What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
That one is slightly different than what I have, but pretty close. I have one of those sensor things that the lower arrow is pointing to. Mine have a short wire instead of the long wire, then there's a long wire that plugs into the "live unit" and the short wire coming off the sensor. The thing I screwed into my manifold looks different than that one.
I figured oil pressure and oil temperature, but I dunno if those are the things I should monitor the most or not.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#2 | |
Looking at the manual again, the little hose is for vacuum/boost. You just screw a 1/4" FPT to 1/8" nipple into the hole in the manifold to connect it to. That sensor that you installed there is probably your pressure sensor (to be used for oil pressure).
| Upper driver's side glove box w/ holes cut for gauges | PETERPOOP | Items for Sale by private party | 9 | 07-31-2011 07:21 PM |
| Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-19-2009 11:40 PM |
| My new gauges set up | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 30 | 04-19-2009 08:50 PM |
| Mechanical vs Electric Gauges? | PETERPOOP | Forced Induction Forum | 13 | 04-06-2009 01:25 AM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
