Old 10-15-2012, 04:40 PM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
EDIT: DISREGARD THIS POST.
No, I don't think CTScott is telling you to switch those two.
I think your oil pressure thing that you have in there is fine where it is.
As for the skinny hose that's coming out of your live unit, that has to tap into your intake manifold. This way your live unit will detect how much boost you're getting and inform you when you look at your boost gauge.
Old 10-15-2012, 08:37 PM   #2
With the Blitz that hole in the manifold is specifically intended for connection of a boost gauge. I initially missed the fact that the boost gauge for the kit has a hose, rather than electronic sender. If you used the pressure gauge sensor there, you would not see the negative pressure of the vacuum and would barely move the gauge for the six pounds of boost generated by the S/C.
Old 10-15-2012, 10:33 PM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
OK my bad! Sorry Mason.
So you're saying to remove the pressure sensor and replace it with the 1/4-1/8" fitting for the vacuum line from the live unit.
Where does the sensor go to? Are there other orifices?
Old 10-15-2012, 10:36 PM   #4
The pressure sensor is for oil pressure. You would mount that somewhere where you can see the oil pressure, like at the filter sandwich adapter that they mention in the instructions.
Upper driver's side glove box w/ holes cut for gauges PETERPOOP Items for Sale by private party 9 07-31-2011 07:21 PM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
My new gauges set up PETERPOOP Cosmetic Modifications (Exterior/Interior) 30 04-19-2009 08:50 PM
Mechanical vs Electric Gauges? PETERPOOP Forced Induction Forum 13 04-06-2009 01:25 AM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
