![]() Drives: 2008 Yaris Join Date: Oct 2012
This is the point I am presently at:
I have installed the stalk and clutch switch, done some of the wiring. All wiring from the ECM and Clutch Switch up to the steering column, where there is only one horn wire that runs through the spiral cable.....this is where I have become stuck. I now realize that this is all for naught. Now reading through this Forum, I have found that I maybe chasing shadows. Original Rostra Kit? Does this mean that the ''stalk'' I presently own, needs some additional parts? Or is the Original Rostra Kit something else altogether? Or do you mean the ECM I have isn't compatible? Where would be a good place to find this? Would you be so kind as to direct me from this point to a remedial solution? If you were I, where would you go from here? Many thanks
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| cruise control question | caineroad | General Yaris / Vitz Discussion | 2 | 03-03-2012 02:26 AM |
| Rostra 250-1731 cruise control kit for Yaris | PeetYaris | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 06-26-2011 06:48 PM |
