Old 10-21-2012, 08:05 PM   #1
^ None of them are sway bars, to be correct about it. You make it sound like the UR or TRD ones are. They are not. All are torsion bars. For the sake of common language we use "sway bar" so more people will understand where it goes and (more or less) what it does.
Further, I haven't seen a Whiteline sway bar break. For any car, not just the Yaris. Doesn't mean it hasn't happened, of course.
With that said, we offer both types of torsion/sway bar so each customer can choose what's right for them.
Old 10-21-2012, 11:59 PM   #2
Sirius-XM
Toyota (TM) Shareholder
Sirius-XM's Avatar
Drives: 2007 Jade Yaris Sedan
^ None of them are sway bars, to be correct about it. You make it sound like the UR or TRD ones are. They are not. All are torsion bars. For the sake of common language we use "sway bar" so more people will understand where it goes and (more or less) what it does..
Where do I make it sound like the UR and TRD are real sway bars. I clearly stated in a previous comment that the TRD sway bar isn't really a sway bar. The UR bar is similiar to the TRD bar.
The Whiteline sway bar has only been out a year or two. More parts mean more points of failure. I have the TRD bar. I would have no issues with using the UR bars that you sell. I would not be comfortable with the Whiteline.
Sirius-XM is offline   Reply With Quote
Old 10-22-2012, 01:19 AM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The Whiteline looks much larger in diameter and its adjustability is a real advantage. The only reason I got the TRD was that it tucked up so neatly underneath the car.
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
