^ The coil springs are for up and down movemente. We are talking about the horizontal "spring" that we call a sway bar/torsion bar. Different movement. It doesn't come with the car, but the torsion/sway bar is what we are talking about. When the car goes into a corner, the bar resists being twisted, just like your spring example. This transfers weight.
The front bar on the Yaris IS a sway bar - independent suspension up front.
#2 | |
![]() ![]() ![]() Drives: Miss my Yaris, love my Jeep jk Join Date: Aug 2011
Quote: Originally Posted by Sirius-XM The Yaris has a torsion beam suspension so the sway bar isn't really a sway bar in the conventional sense but is instead a reinforcing spring for the torsion beam. It attaches to trailing arm part of torsion Beam. If this is the TRD Sway Bar for the Yaris (PTR11-52071), the installation instructions over at TRD Sparks where I got mine. A sway bar is indeed a torsion spring, but the rear suspension on the Yaris isn't a torsion bar set-up, as Sirius-XM says it is. It isn't. The sway bar isnt "a reinforcing spring spring for the torsion beam", as he states. It's a torsion spring to be installed (in the case of the Yaris) on a coil-sprung solid type rear axle. Same net effect, but not acting on a torsion bar type of axle.
I'm the Prez at my house...in fact I cruise around in YarForce One! When I'm not driving my Yaris, I'm doing this: http://gogogordy1.wix.com/scooter-aficionado |
#3 | |
Quote: Originally Posted by Sirius-XM The Yaris has a torsion beam suspension so the sway bar isn't really a sway bar in the conventional sense but is instead a reinforcing spring for the torsion beam. It attaches to trailing arm part of torsion Beam. If this is the TRD Sway Bar for the Yaris (PTR11-52071), the installation instructions over at TRD Sparks where I got mine. A sway bar is indeed a torsion spring, but the rear suspension on the Yaris isn't a torsion bar set-up, as Sirius-XM says it is. It isn't. The sway bar isnt "a reinforcing spring spring for the torsion beam", as he states. It's a torsion spring to be installed (in the case of the Yaris) on a coil-sprung solid type rear axle. Same net effect, to minimize roll but not acting on a torsion bar type of axle in this case. http://en.wikipedia.org/wiki/Torsion_bar_suspension
| xA or xD front sway bar fit in to 07 Yaris | yariseggvvti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-29-2012 09:47 PM |
