Old 10-28-2012, 10:17 AM   #1
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
vitz high idle problem after cleaning the throttle body.
hi im new here. im andy from malta :) . since i need help ....i serviced my vitz 2001 1.0 auto. so i decided to clean the throtle . i pulled it out from the engine u sprayed some carb cleaner to shiny metal. later i unsrewed the idle control valve from it and cleaned it to, replaced new gasket and put it back. i put the throttle back , fixed all vacumm pipes to ensure for no vacuum leaks.. started the engine and it idle good anough for 2 minutes, but later it started to built up revs...high as 2500 - 3000. i turned it off, disconnected the battery for ecu refresh but no luck, still high reving...later i disconnected the idle control valve from it. and it worked fine but surly it come on the check engine, cause off disconnect the iac. but as i connect it back again it rev highly again....please any one can help? never happened to me before.
dindy is offline   Reply With Quote
1.8L throttle body dimensions drawing CrankyOldMan DIY / Maintenance / Service 5 03-09-2016 10:30 PM
1ZZ Throttle Body and Weapon R Filters bladesmith6 Items for Sale by private party 9 10-19-2011 06:41 PM
Throttle Body spacer? jekqmb Performance Modifications 2 10-05-2011 12:02 AM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-02-2007 12:38 AM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 01:03 PM
