Old 11-01-2012, 06:59 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
What sensor is used for RPM, if it's the same as the crank then you can't mess with it or your timming will also be screwed along with injection.
Old 11-01-2012, 07:05 PM   #2
Without modifying the 6,600 RPM constant in the firmware, any modification to the limit will require manual adjustment of the maps via a piggyback.
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
Turbocharged Dyno Result cdydjded Forced Induction Forum 24 08-23-2010 10:54 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
