There is another thread on here from yesterday with another person having the same thing happen. You can actually make your own tool with a piece of steel and two grade 8 bolts that will fit into the holes. Just take a piece of flat steel and drill two holes, spaced for two opposite holes in the pulley, and stick the bolts through (either tap the holes for the bolts or put nuts on the back side).
#2 | |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Do you know the torque specs on that pulley nut cover thing I posted above?
Subcompact Culture: The Small car blog |
The service manual considers the compressor to be a one piece part, so there are no specs for the pulley.
#4 | |
Out of curiosity, the part that came off is designed to come off to replace the belt, correct? If so, does Toyota offer a proprietary tool for this piece?
No. The belt can be replaced without removing the pulley. I am not sure if there is a SST, since Toyota just replaces the entire compressor.
| Word Association | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 7373 | 10-04-2011 11:43 PM |
| Custom front end | spdas | Cosmetic Modifications (Exterior/Interior) | 18 | 03-09-2011 07:56 PM |
| End of a decade? | yaris-me | Off-topic / Other Cars / Everything else Discussions | 4 | 12-31-2009 01:12 PM |
| aftermarket front sway bar end links? | jookybanana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-09-2009 12:26 AM |
| Review: Adjustable Sway Bar End Links | m911gt | Performance Modifications | 9 | 04-29-2009 10:25 AM |
