Old 11-28-2012, 10:40 PM   #20
Originally Posted by DJYojimbo View Post
How many ft lbs is it supposed to be?
There isn't a torque measurement for a belt, but rather a deflection and a tension measurement. They point to check is half way between the alternator and the crank pulley.
Deflection:
New belt 7.0 to 8.5 mm (0.28 to 0.33 in)
Used belt 11 to 13 mm (0.43 to 0.51 in)
Tension:
New belt 539 to 637 N (55 to 65 kg, 121 to 143 ld)
Used belt 245 to 392 N (25 to 40 kg, 55 to 88 ld)
pulling the AC belt pulley on front of compressor yaris9876 DIY / Maintenance / Service 6 07-19-2012 10:12 PM
Squeaky belt after pulley install? Black_griffin6 DIY / Maintenance / Service 12 07-01-2012 10:17 AM
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 01:51 PM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 09:05 AM
