Old 12-10-2012, 01:56 PM   #1
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
back from my mechanik right now...we can get wtf is happing. ok he suggested me to take it to a computer scanner...anyone knows if the code will be store on the ecu? cause sometime the cel is and some time not. or i need to scan it when the cel is on?? thanks
dindy is offline   Reply With Quote
Old 12-10-2012, 02:54 PM   #2
The code should be stored, even if the light is out. You can buy a cheap code scanner to use yourself for under $20 US.
check engine code P0101 bugg_master Performance Modifications 6 09-24-2016 01:41 PM
engine check light Capsat DIY / Maintenance / Service 1 06-24-2012 01:03 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
