Old 02-04-2012, 11:24 PM   #1
bugg_master
Drives: yaris sedan type s
check engine code P0101
hey u guys i recently upgraded my intake to an injen intake and a week later my check engine light came on...i rechecked the gas top to make sure it was closed tightly and today i just ran the test on it with the OCB2 the code that popped up was P0101 and P0171....i double checked the hoses that connects to the intake to make sure it was tightened but the lights still on. anybody have any idea about whats going on??? i really dont want to take it to toyota if its something i could do it myself. Thanks for reading and you opinions/suggestions!
bugg_master is offline   Reply With Quote
Old 02-04-2012, 11:50 PM   #2
bugg_master
noooooo i shouldve put this under the maintenance/service thread....y didnt i see that!!!!! :(
Old 02-05-2012, 02:40 AM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
0101 is usually a vacuum leak of some sort or the MAF. Could be that the MAF is sitting too low or too high or is it possible that you put it back on during installation backwards? Did you clear the codes to see how long before it came back?
Old 02-05-2012, 04:09 AM   #4
bugg_master
i looked online to see how to reset the check engine light but the online thing that mainly showed online was reseting the maintenance light. i also tried taking out the fuse but its still showing....i screwed on the maf in all the way but i havent tried rotating it...i'll turn it around tomorrow and well see if the lights still there. but how could the maf be either too high or too low?
Old 02-05-2012, 10:42 AM   #5
fnkngrv
fnkngrv's Avatar
it all depends on the mounting point on the intake piping. There was an issue with the AFE intake in regards this and it also came with spacers. As for resetting the code you can always disconnect the battery for 10-20 minutes.
Old 02-05-2012, 04:20 PM   #6
KSIbucky
KSIbucky's Avatar
the MAF has to be put in the right direction and it clicks in.
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 09-24-2016, 01:41 PM   #7
CJDA9
Drives: 2010 toyota yaris sedan 5spd
Hey sorry to revive an old thread but I am having the same problem and codes showing up with my car after installing a short ram intake recently. wondering if anyone has found a fix.
CJDA9 is offline   Reply With Quote
Differntial diagnosis for the check engine light yaris sedan dante2086 DIY / Maintenance / Service 1 12-18-2010 09:04 AM
Check engine light Mr Yarisman Performance Modifications 7 10-24-2009 11:10 PM
ODB2 Check engine code reader Arkhangel Performance Modifications 11 02-25-2009 04:13 AM
Nitto Mid-Pipe Check Engine Light fix Jerkratt Performance Modifications 77 12-01-2008 07:23 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
