Old 10-27-2008, 06:38 PM   #1
Jerkratt
Jerkratt's Avatar
Nitto Mid-Pipe Check Engine Light fix
so i have the mid pipe and i remember before the hack there was a "help!" part number for the o2 censor was wondering if anyone still had that part number as i wanna go there and get one
"It hurts more when its wet"
Old 10-27-2008, 08:52 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i believe its HELP part #4240 at any parts store.
Old 10-27-2008, 08:59 PM   #3
Return of the Yarii
Drives: 2007 Sedan S
anti seize
Return of the Yarii is offline   Reply With Quote
Old 10-28-2008, 02:55 AM   #4
jronald
jronald's Avatar
Drives: Black NCP91R
Found this link. Hopefully, this will work..
http://http://www.paladinmicro.com/M...Eliminator.htm
jronald is offline   Reply With Quote
Old 10-28-2008, 02:59 AM   #5
wow.
Old 10-28-2008, 03:12 AM   #6
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
wow is right i never even knew you could do it that way
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-28-2008, 03:56 AM   #7
ddongbap
Lol. Trick-my-o2-sensor.com !
Old 10-28-2008, 09:58 AM   #8
Klink10
Klink10's Avatar
Did you have any problems with the mating of the mid-pipe? Someone out there had a source for a custom extension for the sensor. Can't remember who though. Been really considering getting this so I can add my header but waiting till the bugs are finally gone.
Old 10-28-2008, 11:12 AM   #9
03Z33
03Z33's Avatar
Drives: TCR10
What some people have done is have the muffler shop weld a tight 90deg bung on the pipe which will then allow you to stack the two extenders without the sensor coming in contact with anything below. The wire is just barely long enough.
03Z33 is offline   Reply With Quote
Old 10-28-2008, 03:33 PM   #10
Jerkratt
Jerkratt's Avatar
so....then 1 wont work?
Old 10-28-2008, 03:46 PM   #11
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
E-mail this guy wayne92slc@yahoo.com he makes a piece that will move the o2 sensor far enough away from the gasses to the point where it doesnt set a CEL. he has them in stock $38 shipped. i will be ordering mine next week
Old 10-28-2008, 03:56 PM   #12
Klink10
Klink10's Avatar
Thanks Whooppee....saving that for later
Old 10-28-2008, 05:10 PM   #13
at3GG
at3GG's Avatar
Drives: 07 metmet LB
To any who have the nitto, when you removed your stock mid, did you have a problem "unscrewing" the o2 sensor? I tried to remove it to wrap the midpipe with thermal wrap and it sun a couple of times then just seemed to wedge where it was. Anyone else have this happen?
To those with a custom midpipe...if i bring my car to have a custom mid made, should i assume that there will be no CEL issues or should i inform them of the issue? Also around how much did it run you guys? Thanks.
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 10-28-2008, 06:18 PM   #14
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
jerkratt, need to use both of those defoulers...been using the defouler now for 1 week after i installed a new header, NO CEL!
kuro, u might just want to wait until the ecu relearns!
Old 10-28-2008, 07:02 PM   #15
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
The CEL is NOT an issue... Is just the sensor doing it's job.
The function of the sensor behind the primary cat is to monitor the adecuate functionality of the cat converter.
When you remove / delete the cat converter the sensor obviously will sence a cat failure and throw a CEL.
The Nitto midpipe is a catless unit threfore it will trigger the CEL.
When you say you are going for a custom mide pipe are you planning to go catless also? If so you will have a CEL and you will need one of the already mentioned CEL fixes.
If you keep your cat or install a new cat to the custom midpipe you should be alright and will not need any fix.
Just my recomendation:
Keep the cat... the gains for going catless should be minimal on this engine. Just ask your shop to make your midpipe from the cat back...
Old 10-28-2008, 10:57 PM   #16
Malaya1221
Malaya1221's Avatar
^ didn't even notice that u only used one of them....yeah the other one might help!
Old 10-28-2008, 11:36 PM   #17
Originally Posted by kurokoma-kun View Post
meh! i got these ramps that make it easy to get under the car, and i kinda like messing with it
i put the 2nd antifouler on tonight, just had to drop the pipe off its hangers to get a bit more clearance
A woman who enjoys going down on her car...
Old 10-29-2008, 06:55 AM   #18
ROCKLAND TOYOTA
TRIM HUNTER
besides that i do believe EVERYONE experiences a CEL with the defouler eventually.on the other hand the soldering of the wires looked to be a good deal though........
Check engine light on kcty DIY / Maintenance / Service 19 03-10-2012 08:54 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
