Old 12-12-2012, 10:40 AM   #1
yaris9876
Drives: yaris hatch 07 640K original m
thanks for the pic. when I get that off ,how does the white plastic thing come off??
Do you lift up the whole thing at once or pull 1 part at a time.???Does it unscrew or just pull?
I would think the seal would come from the plastic thing rather than the goo....
additional pics would be great..
What would I expect to pay for a new filter??? Autozone
yaris9876 is offline   Reply With Quote
Old 12-12-2012, 12:40 PM   #2
The top of the tank has a ring that screws on. Toyota makes a special ($300) spanner tool to remove it, and you may be able to find a generic tool from an auto parts place. I use a 3/4" x 3/4" x 12" long piece of hard wood and a hammer to rotate the ring loose (and to tighten it later). The black goo is just for sealing the metal cover. The tank itself has a giant o-ring to seal it.
Here is the ring removed with the O-ring visible:
Here is the connector being removed:
Here is the fuel line being removed by releasing the locking clip:
Here is the vent hose being removed by releasing the locking clip:
Here is the sender unit, which you can lift right out of the tank once you loosen the ring and disconnect the three above:
The plastic clip on the top of the lower portion of the sender is what holds the pump assembly in place. Once you pop the clip you can pull out the pump. I thought that the mesh strainer on the bottom was the actual filter, but everyplace that sells the filter sells the plastic housing that surrounds the pump as the filter. I suggest blasting the strainer with compressed air to clean it as well.
Rockauto.com has the best price on the filter assembly at $23 (elsewhere it runs about $40):
http://www.rockauto.com/catalog/rafr...998768-1370776
"5 Driving Myths That Cost You Money" PETERPOOP Fuel Economy Forum 10 05-24-2011 10:20 PM
Pics of my old water pump out of the car showing where it leaks auxmike DIY / Maintenance / Service 8 11-11-2010 01:51 PM
Unboxing pics of a new Yaris water pump... auxmike DIY / Maintenance / Service 11 11-07-2010 08:00 AM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
