Old 11-06-2010, 06:17 PM   #1
auxmike
auxmike's Avatar
Pics of my old water pump out of the car showing where it leaks
This was a real hassel to do, at least 3 hours of labor for me. The bottom alternator bolt is really hard to get off. My back is quite sore, too.
Be sure to have 1/4 inch drive socket set handy. I also recommend a 1/4 inch drive torque wrench as some things are torqued to inch lbs.
I did'nt have to remove any tires or splash guards or touch any of the engine mounts either.
This is a pretty big job that requires concentration and having the RIGHT tools too. 12mm,10mm,14mm short and deep sockets are needed, 3/8" and 1/4" drives. A good 3/8"breaker bar for that stubborn bottom alt. bolt helps too.10mm,12mm and 14mm box end wrenches are a plus, especially the ratcheting style.
I don't recommend this job as one to "learn" how to work on cars for the first time or for a DIY rookie.
Now... on to the pics!
Old 11-06-2010, 08:23 PM   #2
auxmike
auxmike's Avatar
The way the lower weep hole is designed allows leaking coolant to build up in the chamber below it which is covered by the gold disk with the hole in the middle.
I guess it buys some time for a slow drip to go unnoticed so they don't have to change it until the port fills up enough to cause the coolant to flow out and then shoot around under the hood.
Old 11-06-2010, 10:12 PM   #3
bronsin
bronsin's Avatar
If thats the "leak" thats weird cause a water pump leak involves the seal around the shaft. How much was it leaking?
Old 11-07-2010, 11:42 PM   #4
auxmike
auxmike's Avatar
Not leaking bad. Just enough to leave a small spray under the hood.
There's a weep hole lying behind that cover plate on the pump where you see the pink stuff oozing from...
Old 11-08-2010, 08:01 AM   #5
Klink10
Klink10's Avatar
Thanks for posting the pics.
Old 11-08-2010, 03:17 PM   #6
wooverstone8
wooverstone8's Avatar
When they took the bad water pump out of my Yaris it looked like a colony of bees had constructed a pink beehive around the weep hole.
Old 11-08-2010, 05:17 PM   #7
DARK AGE 53
Drives: 2009 Yaris Onyx
just wondering why you didn't go with the best NAPA water pump instead of replacing it with another Toyota pump, prices range from $63 to $72 for there best new pumps.
DARK AGE 53 is offline   Reply With Quote
Old 11-09-2010, 07:03 AM   #8
1stToyota
1stToyota's Avatar
Or Napa's Altrom Import line, 2 new pumps to choose from...
NEW Altrom Ultra-8 ($25.00)
NEW Altrom NPW ($42.90)
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 11-11-2010, 01:51 PM   #9
JonS
Drives: 2009 3 door Liftback
Anyone have any experience with these Altrom pumps? Doesn't make sense to replace a faulty Toyota pump with another faulty one. Maybe these Altroms are a better option.
JonS is offline   Reply With Quote
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
enobmort42 - Photo-Scavenger Hunt! enobmort42 Photo-Video-Media Gallery 9 03-05-2009 10:52 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
[Detail] [as to make ] Auto Laudering Sérgio Barros Wash, Wax, Detailing, Exterior Repairs 4 08-22-2006 03:56 AM
