Old 12-12-2012, 11:37 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
Eesh. That's bad.
I looked up the labour time, and it's written as 1hr for upper, and 1hr for lower so they are charging full labour for both. The thing is most of the 1hr is spent draining and filling coolant so it should be 1hr for the lower, then 0.1hr for the other hose. It's called "labour overlap" and they should be charging accordingly. Also, don't forget that they wanted to charge full labour time to do the Tstat as well. Again, most of the labour there is from the drain and fill of coolant. So guessing $250 in labour, $100 in hoses and $50 in coolant. There is the ridiculously high $400 for two rad hoses.
I would be tempted to go in and ask them about labour overlap just to see them squirm as I think it's safe to say they were trying to..... hose you.
Head gasket thefalls Forced Induction Forum 12 11-12-2012 12:26 AM
Megan Axleback Gasket slothman86 DIY / Maintenance / Service 6 12-23-2009 09:00 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
rear lip gasket 808yaris Cosmetic Modifications (Exterior/Interior) 6 12-01-2008 08:12 AM
Hood gasket acrbill General Yaris / Vitz Discussion 0 01-05-2007 08:03 PM
