Old 12-17-2012, 01:35 AM   #1
CoryM
Drives: 2009 5-door, 5-speed
For the battery to be bad enough to drag down the output of the alternator, it would also not be able to start the engine.
Little car like the Yaris probably draws >100A so there is still a lot of room to start the car, yet draw the voltage down. Also can be that the battery reserve sucks, but still cranks well (for a short time anyhow). I've seen a few misdiagnosed alternators due to batteries. While it is entirely possible to be an alternator, it's far easier/cheaper for the average guy to charge his battery first and see what happens to his voltage. Especially since he should be doing that before putting a new alternator in anyhow.
Cheers.
Old 12-17-2012, 06:52 AM   #2
Cheers.
Agreed that the battery should be verified before going through the expense of replacing the alternator.
Voltage reading from SG The Spectacle In Car Entertainment + Electronics (audio / video / alarm) 21 08-27-2011 12:33 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
High voltage -m- DIY / Maintenance / Service 7 08-01-2007 09:48 PM
