Old 06-24-2009, 01:56 PM   #1
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Voltage reading from SG
Can anyone with a SG go out and tell me what voltage numbers they are seeing on it? My car won't hit 14v while running no matter what I'm doing or what accessories are on...it usually hovers around 13.7-13.8v which I know is not bad, but seems weird. The lowest it hits is 12.9v with my audio system at full tilt, AC on full blast and all the lights on. I am not experiencing any voltage related problems with the car, just curious as to why this is.
The Spectacle is offline   Reply With Quote
Old 06-24-2009, 01:58 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
13.8V is normal
Old 06-24-2009, 02:05 PM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
13.8 is average..
Old 06-24-2009, 02:27 PM   #4
The Spectacle
Drives: 08 BSP LB
My other car, with HID's on, AC and stereo, hovers around 14.1v. With nothing on, it maxes out around 14.5v. I thought that was average.
Old 06-24-2009, 02:59 PM   #5
what car is it? maybe it's just a different alternator specification... a few 10ths of a volt less should not hurt anything, I mean, most equipment has to run at 12V anyway...
I see 13.6-13.8 pretty much all along when the engine's running...
Old 06-24-2009, 03:26 PM   #6
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
If im driving during the day without lights on and the system on it varies between 14.17-14.23
with HIDS as well on its at about 13.8-14.0
I dont use A/C almost ever.
PG TLD22 8V Line Driver
Old 06-25-2009, 11:55 AM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
right when you start your car you should see it hit 14v... The Alt's goal is to make sure the battery is always fully charged to 12.5V, and in order to charge you have to have a higher voltage than the battery, higher the voltage, and amperage, and the quicker the charge will be. your car DOESN'T need to reach 14V, but it does sound a bit weird that yours does not. It might have something to do with the temperature outside, but I'd think you'd see higher discharges and charging voltages in the winter than the summer.
I dunno
I see 14-14.2 on mine every day for the first ten minutes of the drive. Do you do highway driving much? If i'm doing low RPM's your voltage won't be as high... there's times when i'll see a .5V difference just by changing gear(rpm's).
I wouldn't worry about it too much until you never see a voltage higher than 12v
Old 06-26-2009, 12:08 AM   #8
nth09
Drives: vios
Mine is 13.0 or 13.1 when full engine is running and my ICE turned on. My battery is stock. Is this normal?
nth09 is offline   Reply With Quote
Old 08-18-2011, 09:22 PM   #9
The Spectacle
Drives: 08 BSP LB
Update from the dead.
Stock battery died yesterday. Replaced it with Stinger SPP 1200 and did the big 3 upgrade but still seeing less than 14v @ idle with nothing running. Measures between 13.2 - 13.7 @ the alternator. Anyone have any idea what the stock alternator is rated for?
Old 08-18-2011, 09:26 PM   #10
Brian
Brian's Avatar
13.2-14.8 @2000 rpm is normal. Stock alternator is 80 amps.
Old 08-18-2011, 09:52 PM   #11
The Spectacle
Drives: 08 BSP LB
Did you mean 13.8?
Old 08-18-2011, 09:59 PM   #12
Brian
Brian's Avatar
No. Factory repair manual says 14.8
Old 08-18-2011, 10:06 PM   #13
The Spectacle
Drives: 08 BSP LB
I have NEVER seen higher than 14.1 in my 3 years of owning this car. Even then it was for a brief 1-3 seconds
Old 08-19-2011, 01:12 AM   #14
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
same here. Only in the 13.x range - at 13.0 (sometimes to 12.9) car starts doing a little shake until it goes back up again.
Old 08-19-2011, 01:54 AM   #15
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I am almost always between 13.9-14.1, I'm running a re-wound 120amp alternator.
-Type 07 FFL-
My odometer 03/11
Old 08-19-2011, 07:49 AM   #16
Revsson
Does the OBDII connector read the actual battery voltage?
Perhaps CTScott can answer when he gets back from California?
Old 08-19-2011, 07:20 PM   #17
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
i get 13.4 on average that is with fogs and lights on.....stereo usually eats off another .2 off that for me.
Old 08-19-2011, 11:24 PM   #18
The Spectacle
Drives: 08 BSP LB
Yes. I've verified this with a multi-meter...its within .1 of what you read at the battery and/or alternator
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
possible alternator (voltage regulator) issue jesse1000 Canada 3 03-09-2009 09:10 PM
High voltage -m- DIY / Maintenance / Service 7 08-01-2007 09:48 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
