Old 12-18-2012, 08:22 PM   #1
MadMax
MadMax's Avatar
Yep, even with the 'cool' light off I still find it takes a while for the transmission to warm up sufficiently to shift into OD (4th).
Unless this is happening after you've driving for a while (5-10 minutes) then it is completely normal.
By the way, where are you in the great state of Texas?
Cheers! M2
2nd, 4th & Reverse Gear Not Engaging mesci DIY / Maintenance / Service 3 03-17-2023 07:03 AM
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
Grinding in 4th gear? Black_griffin6 DIY / Maintenance / Service 8 05-30-2012 03:54 PM
No 4th gear in A/T? caineroad General Yaris / Vitz Discussion 13 09-11-2009 06:47 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
