Old 05-24-2012, 09:14 PM   #1
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Grinding in 4th gear?
Hey guys,
I recently changed my transmission fluid on my MT '09 liftback, I used Redline MT-90 (as recommended by many people here) and it has been awesome...until now.
I changed it on Tuesday which was 2 days ago, and now every time I go from 3rd to 4th it grinds slightly going into 4th, it doesn't do this with any other gear.
Is this to be expected? Will it go away after time? I'm really worried about it as it's never done this before, and I was driving it earlier today and it was fine, it was only until I drove it for a long while today that it started doing it.
My car has about 30k on it too, so I don't think the syncros (sp?) could be going bad.
Anyone have any advice?
Black_griffin6 is offline   Reply With Quote
Old 05-25-2012, 12:09 AM   #2
Viperoni
Drives: 2005 Toyota Echo
Very strange, I had nothing but good times when I switched to MT-90....
Are you sure the level is correct?
Are you still able to shift into 1st at speed?
2006 Saturn Ion Redline
Old 05-25-2012, 02:06 AM   #3
Black_griffin6
Yeah, it took 2 quarts.
Every other gear is fine except the occasional 4th gear grinding.
It's only for a split second too, it's right before I enter third I can hear a little grinding sound but it still goes in just fine.
I thought I wasn't pushing in the clutch hard enough but that wasn't the case.
I'm going to drive it here a little bit to work, maybe it will go away after time.
Old 05-25-2012, 11:10 AM   #4
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
try changing tranny fluid to synthetic...i prefer amsoil which got rid of my grind in 2nd and 3rd on my celica..took 3 weeks from when i changed it though for grind to completely stop i guess oil need to settle
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 05-25-2012, 11:48 AM   #5
Hershey
The MT-90 is claimed to be a true synthetic ( http://www.redlineoil.com/product.aspx?pid=46&pcid=7 ) and no issues in the '08 we had . Only improvements . Give REDLINE a call and see if they'll possibly reimburse or give you 2 more quarts . Very good people there . http://www.redlineoil.com/contact.aspx . Good luck and keep us updated .
Old 05-25-2012, 12:08 PM   #6
marcus
toyota
marcus's Avatar
sorry didnt read that he changed the oil.. makes sure its the right oil specs and maybe give it 2-3 weeks to settle...
Old 05-25-2012, 12:40 PM   #7
Black_griffin6
Well I took it for a drive today and I think i've come to the conclusion that it's only happening when the transmission is warmed up, and the grinding occurs when I have the clutch pedal fully pressed and i'm going from 3rd to 4th.
Old 05-30-2012, 03:18 PM   #8
2o6
Drives: 2007 Liftback
I have noticed the exact same thing.....I can't even get it consistently to do it.
However, I drove a brand new Scion xD, and I got the same sensation. Toyota dealer told me there is nothing wrong with the transmission (no shavings, ect) so I'm going to be careful and ignore this.
2o6 is offline   Reply With Quote
Old 05-30-2012, 03:54 PM   #9
Em_
Drives: 2007 Yaris
i still tend to belive that the best tranny fluid for this trasmission is the the one from the dealer and nothing else
if i would be you i would have it changed to the OEM one
Em_ is offline   Reply With Quote
2nd, 4th & Reverse Gear Not Engaging mesci DIY / Maintenance / Service 3 03-17-2023 07:03 AM
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
Gear shift grinding KSIbucky DIY / Maintenance / Service 2 07-18-2011 08:03 PM
Grinding noise when switchingfrom second to third gear Stiv DIY / Maintenance / Service 2 01-04-2011 04:35 PM
No 4th gear in A/T? caineroad General Yaris / Vitz Discussion 13 09-11-2009 06:47 PM
