Old 12-19-2012, 11:54 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Have you checked to make sure the. Heat shield isn't loose. It'll make a squeaking sound like that.
And you need to check voltage on the front sensor not resistance to determain your reading.
Old 12-19-2012, 12:42 PM   #2
mokmok
Drives: Yaris RS 2007
the repair manual states the values in Ohms not in Volts and the heat shield does not move at all
mokmok is offline   Reply With Quote
vitz high idle problem after cleaning the throttle body. dindy DIY / Maintenance / Service 20 11-07-2012 05:05 PM
chirp/squeak noise just off idle when cold tadc DIY / Maintenance / Service 14 02-20-2011 03:09 PM
annoyin noise (ticking or rattling) on idle.. abdallah380 DIY / Maintenance / Service 2 04-18-2009 05:40 PM
high pitch whine at 100km/h Moore General Yaris / Vitz Discussion 9 06-11-2007 07:22 PM
