#1 |
![]() Drives: 2007 yaris 3dr ce Join Date: Jun 2007
high pitch whine at 100km/h
I started getting this last night. When I get to, or very close to 100km/h there is a high pitch whine coming from the engine, or somewhere in the front end. As soon as I lay off the gas it stops, but starts again when I hit the gas. Has anyone else experienced this. Does anyone know what this could be?? I have just over 1000km's on the car if this helps.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
i've never experienced this.
#3 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Is it only at 100km/h, or does it start there and sustain above that speed?
Can you determine if it is from the engine, transmission or steering/suspension/wheels? Is it a mechanical whine, or an air movement whine?
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#4 |
It is not from the air movement, it is defitnetly mechanical. It is not ear shattering, but it is there. It sounds like it is coming from the front of the vehicle. I am assuming the engine because the second I lift my foot off of the gas it goes away, and comes back just as quick when I hit the gas again. Starts there and sustains it(from 100km/h).
#5 |
do you have a power adapter plugged in? sometimes you get a whine in the speakers from the motor during high rpm.
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
#6 |
Drives: lil red 5-door Join Date: Sep 2006
yes, I'm thinking electrical interference causing the whine in the speakers, very common thing to happen...
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#7 |
GIGA...DRILL...BREAKER!!!
Drives: Lagann. ;P Join Date: Feb 2006
Ion flux capacitors. They always kick in just before the thermal couplings engage, which reduces the quantum-level stress on your frame. Nothing to worry about!
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
or a phaser on overload, have you checked all the ventilation ducts?Seriously though, could it be a belt slipping? Or does that only happen at low speed? |
#9 | |
#10 |
![]() ![]() Drives: 2007 5-Door Hatchback Join Date: May 2007
When I was trying to destroy my engine by driving in third instead of drive (um, not on purpose *cringe*), it would get noisy at 100km/h. No high pitched whining, though. You're sure you're in the right gear?
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
| Tranny Whine | jmjonesey | DIY / Maintenance / Service | 11 | 05-23-2007 10:32 PM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 01:23 AM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
