try re-installing the stock muffler and see if that fixes the problem. Maybe the knock sensor is overly sensitive.
![]() Drives: Yaris RS 2007 Join Date: Apr 2012
Is there any way to bypass the knock sensors for testing purpose?
Try connecting a 120K to 280K resistor to the knock sensor connector, in place of the sensor.
Ok I tried that, still no change at all
I also noticee when I am on the highway if i press the clutch the rpm drop to 500 then go up to 1500 then 1000 then sudden drop back to 500 :s
| vitz high idle problem after cleaning the throttle body. | dindy | DIY / Maintenance / Service | 20 | 11-07-2012 05:05 PM |
| chirp/squeak noise just off idle when cold | tadc | DIY / Maintenance / Service | 14 | 02-20-2011 03:09 PM |
| annoyin noise (ticking or rattling) on idle.. | abdallah380 | DIY / Maintenance / Service | 2 | 04-18-2009 05:40 PM |
| high pitch whine at 100km/h | Moore | General Yaris / Vitz Discussion | 9 | 06-11-2007 07:22 PM |
