Your 2009 US Yaris should have the head unit that has the AUX button on it. If it does, then all you need is the OEM Aux jack and possible the cabling for it. pop out the plastic piece in front of the ebrake lever and if you see two connectors sitting under that piece, then you just need the jack. If you only see one (which has a single row of pins) then you need both the jack and the cabling. I have both available if you are interested.
#2 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
PS: Had a look in my 09 with a manual trans, the connector is taped up to the right of the shifter. You can't see it under the panel below the E-brake. If you pull up the shifter boot you should see it, and two others. Cut the white tape to release it and it will reach under the E-brake. Cheers. |
#3 | |
There is an OEM ipod interface kit, but it has the 30 pin Apple connector.
| Tags |
| auxilery, oem radio, usb |
| For Sale: Pioneer DEH-P6200BT Head Unit w/BT & iPod - $60 | CTScott | Items for Sale by private party | 6 | 06-28-2012 06:11 PM |
| Good Head Unit Replacement For XM | greenlightning | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 06-21-2012 12:46 PM |
| 2006 Yaris Hatchback Replacing Stereo Head Unit help | lauren24 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 07-01-2010 11:13 PM |
| Help me pick out a new head unit / receiver. | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 10-23-2008 01:48 AM |
| In car Audio - Head Unit installed but a little problem... | YoyotaTaris | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-06-2007 12:34 PM |
