Old 03-26-2007, 03:04 PM   #1
TheMaskedMan
Drives: 92 Toyota Camry
Interference or Non-Interference Engine
Is the engine in a 2007 Yaris a interference or non-interference engine?
TheMaskedMan is offline   Reply With Quote
Old 03-26-2007, 04:31 PM   #2
clayky
Drives: '07 Yaris S Sedan
Probably interference being it's chain-driven. On the other hand I doubt you'll ever have to worry about it.
clayky is offline   Reply With Quote
Old 03-26-2007, 07:17 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Why do you wonder? Chain driven or belt driven has nothing to do with it being interference or non-interference as both can be either. Most modern engines are interference, however, I wouldn't worry about it. The yaris is chain driven with no scheduled maintainance.
PetersRedYaris is offline   Reply With Quote
Old 03-26-2007, 07:38 PM   #4
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
has anyone ever wonder why did they designed it chain driven? nothing against that of course... just wondering...
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 03-26-2007, 07:38 PM   #5
acrbill
Drives: Polar White Hatch
With 10.5:1 compression its a safe bet to say its interference.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 03-26-2007, 07:53 PM   #6
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
It's interference.
Chain driven engines are more reliable (especially with variable timing setups) and cheaper to maintain than belt driven engines.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 03-26-2007, 10:21 PM   #7
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Unless the chain breaks at highway speeds....then you're screwed.
jdubau55 is offline   Reply With Quote
Old 03-26-2007, 11:20 PM   #8
Kitt
Kitt's Avatar
that must hurt
Old 03-27-2007, 12:12 AM   #9
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
belts are a pain!
Before this I had a '94 geo prism (toyota corrolla). The timing belt had to be changed every 60k miles, and the water pump failed at 60k intervals too.
fu_im_from_texas is offline   Reply With Quote
Old 03-27-2007, 12:25 AM   #10
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
yeah, my 86 gti had a timing belt. never again will i own a car with a timing belt.
chain driven all the way!
tekmoe is offline   Reply With Quote
Old 03-27-2007, 12:42 AM   #11
PetersRedYaris
I wouldn't have bought a Yaris if it had a timing belt. Low maintainance was a big selling point for me. Timing belts are a scam IMO. It pisses me off how a car company can design a car with a $500-$600 60,000 mile belt change. Toyota is of course not that expensive as they are the only company to offer flat rate timing belt changes depending on 4, 6, or 8 cylinder. I've owned Mitsubishi (Montero) and Nissan (Pathfinder) vehicles and $700 is not uncommon for a T-belt service. I get angry just thinking about it.
Old 03-27-2007, 09:06 AM   #12
TheMaskedMan
How often do you have to change the chain? and if it breaks are you screwed like you would be if a belt broke?
Old 03-27-2007, 02:45 PM   #13
Nautical Yaris S
1.5L of FURY!
Drives: 2007 Yaris S Sedan, 5 speed
no timing chain maintenece is listed in the owners manual.
think of the older cars from the 60s and stuff. those engines still run w/ no overhaul because they all have chain-driven cams. unless the chain goes out of tolerence and skips a gear, you are fine. but i cannot see that happening unless you are running 22lbs of boost, or a 200 shot of Nitrous... bboth of which would blow the bottom end before the timing chain broke :)
Nautical Yaris S is offline   Reply With Quote
Old 03-28-2007, 01:39 AM   #14
PetersRedYaris
Never, NO scheduled maintainance. IF it broke, yes, you would be screwed. I have NEVER heard of that happening on a Toyota, however.
Old 03-28-2007, 11:09 AM   #15
redyaris
Shiny Chromey Coolness
redyaris's Avatar
OMG...no timing belt change required?!?!?!? There is a GOD!
It just gets better and better. Im glad I bought this little car.
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 07:20 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 08:17 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 11:45 PM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 01:15 PM
