Old 01-06-2013, 08:23 PM   #1
If you just drain it via the drain plug you will only get less than 2 of the 6 quarts out. If you also drain the tranny cooler portion of the radiator (by removing the hose clamps and pulling the rubber hoses off the metal nipples of the radiator) you will get another 1/2 to 3/4 of a quart.
Unless you pull the valve body and torque converter you are only doing about a 50% change with the amsoil.
Old 01-06-2013, 08:26 PM   #2
NorrisB
How do you know it has 6 QTs?
NorrisB is offline   Reply With Quote
Old 01-06-2013, 08:39 PM   #3
From the spec document on the U340E transaxle:
Fluid Capacity Liters (US qts, Imp.qts) 6.4 (6.78, 5.63) (including differential)
Old 01-06-2013, 08:44 PM   #4
Old 01-06-2013, 09:30 PM   #5
mensajero
Drives: Yaris Sedan
BTW, I also plan on changing the Transmission filter.
The reason why I asking is because I have a 1997 Toyota RAV4, 5 speed. I installed an oil cooler and it works for both, the axle and the gear box.
Which means the transmission and the axle work independent from each other? Am I correct? Which Amsoil oil does the axle uses?
mensajero is offline   Reply With Quote
Old 01-06-2013, 09:35 PM   #6
The Yaris automatic is a transaxle, which means it's an all in one unit. I am not sure on the amsoil AT Fluid. Toyota only recommends genuine Toyota ATF WS.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
