Old 01-06-2013, 08:26 PM   #3
NorrisB
If you just drain it via the drain plug you will only get less than 2 of the 6 quarts out. If you also drain the tranny cooler portion of the radiator (by removing the hose clamps and pulling the rubber hoses off the metal nipples of the radiator) you will get another 1/2 to 3/4 of a quart.
Unless you pull the valve body and torque converter you are only doing about a 50% change with the amsoil.
How do you know it has 6 QTs?
NorrisB is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
