Old 01-09-2013, 10:13 AM   #1
Originally Posted by Bluevitz-rs View Post
What's the inside diamater of the pipe on the new intake? If it's any bigger than stock the MAF will read less air passing by and give less fuel making LESS power.
^ This. You never answered the question about inside diameter. What kit are you running?
The ECU is very particular about air passing the MAF. Deviate from 2.25" inside diameter on the pipe and you'll typically run into problems.
Old 01-09-2013, 12:45 PM   #2
discomark10
Drives: 02 Yaris 1.5 T-sport
ill have to check it out tomorrow
Did you disconnect the battery when installing, so your ECU can relearn with your new intake?
yes but only for a couple min, will be tryng it tomorrow also
discomark10 is offline   Reply With Quote
Old 01-09-2013, 02:42 PM   #3
discomark10
just checked, its 2.32" (59mm) rather than 2.25" (57mm) .... (25.5cm2 over 27.3cm2)
Only a tad bigger, wouldn't Imagen that small a difference will cause a problem would it?
Old 01-09-2013, 04:23 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
2734mm2 = 59mmŲ
2551.75mm2 = 57mmŲ
That's a 7% jump with no additional fuel.
Old 01-10-2013, 10:08 AM   #5
discomark10
So today I had another go at sorting it out. Reset the ecu as sujested. It did run better but still no where near right.
This seems to be the problem, I made a restrictor to put inside to reduce the ID of the tube and it helped allot! I still think it was down on power a lil bit.
Ive put it back to standard untill I can remake it with a smaller ID tube or of course get a premade one.
Does anybody know what size ID the aftermarket one is?
WTB Forced Induction kit JohninVT Willing to Buy by private party 5 11-12-2012 03:24 PM
how to fit induction kit to my p1 daveyboigt Performance Modifications 0 10-21-2012 05:06 PM
Induction air filter on yaris diesel - good or bad?!?! Ziishan DIY / Maintenance / Service 3 10-20-2012 08:43 AM
VIS jdm rs body kit Dperry Cosmetic Modifications (Exterior/Interior) 2 05-06-2012 11:00 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 08:42 PM
