Old 01-16-2013, 09:47 PM   #1
Originally Posted by sroberts View Post
Thanks CTScott, that helps a lot!
So I am thinking I got the wrong key fob for my Yaris since I cant get it to program at all. Does anyone know what the correct part number would be for a FOB with electronics for a 2007 Sedan?
89070-52860 or 89070-52730
Old 01-17-2013, 09:44 AM   #2
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
well poop. I bought a 89070-52730 and it wont program. Any suggestions on why the Yaris wont program it? I followed the instructions exactly, tried it like 10 times.
The description says it must be programmed by a Toyota dealer but I am assuming they would just be performing the procedure listed above?
http://www.amazon.com/Keyless-Remote...433742&sr=8-1&
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 01-17-2013, 10:19 AM   #3
If none of your remotes work, then the problem may be the receiver, rather than the keys' transmitters.
Old 01-17-2013, 10:23 AM   #4
sroberts
sroberts's Avatar
My original remote works fine, I swapped the electronics into a new shell, the original shell started coming apart. I was hoping to finally after all these years get a second fob so both my wife and I have one just wont seem to take.
Old 01-17-2013, 11:10 AM   #5
The EPC shows the 89070-52730 part as replacing the 89070-52860 one. Perhaps they really are not compatible. If you want, PM me your VIN, and I can tell you what part number came with your car.
Also, inside of the transmitter there should be a label on the electronics. Compare your old and new ones.
For example, the key that I have on hand (that came with a steering column that I bought off ebay for a project), says:
Tokai Rika
MDL B44TA
ETC094LPD0451
05015/POSTEL/2007
2344
Old 01-17-2013, 10:03 PM   #6
sroberts
sroberts's Avatar
Original Electronics says:
MDL B41TG
FCC ID:MOZB41TG
IC:2584A-B41TG
TOKAI RIKA CO. LTD
RVLTDB405-326
My eyes aren't great so I may have gotten my 0 and D's mixed up.
Old 01-17-2013, 10:48 PM   #7
MDL B41TG
FCC ID:MOZB41TG
IC:2584A-B41TG
TOKAI RIKA CO. LTD
RVLTDB405-326
The "FCC ID:MOZB41TG" ones are what are normally found in a Yaris. The one that I have is from a 2006 Canadian Yaris, which is why it doesn't have the FCC ID.
Did you check the new one?
Tags
keyless, remote, wireless
Keyless Entry stopped working but buttons do work! worduphomes In Car Entertainment + Electronics (audio / video / alarm) 5 01-17-2013 09:35 PM
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Keyless Entry Remotes are dead... now what? Zanutto General Yaris / Vitz Discussion 7 01-11-2012 05:17 AM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 02:11 PM
