#1 | |
Not sure about Toyotas, but on most motorcycles the intake shims are the same thickness, and the exhaust are also matching. If the 1NZ-FE is the same way, buying a trashed engine will not help.
![]() Quote:
![]() Drives: 2007 Yaris hatch Join Date: Feb 2012
Hopefully this isn't the case. I'll know right away, as the lifters are marked with a number corresponding to their length. If I'm lucky, there will be at least one or two in there that will get me where I need to be with my adjustment.
#3 | |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
Even IF they were marked, the numbers would be irrelevant due to wear, as you need to measure the gap, then the actual thickness of the lifter bucket, do the math for optimal gap, read the chart to see which replacement you will need.
Cheapest DD I could find!! |
#4 | |
#5 | |
Asshole
Asshole
35 different sizes.
No, the factory ones are not all the same, they are sized to fit from the 35 available, at the factory.
| VALVE ADJUSTMENT INTERVAL | jemmah | DIY / Maintenance / Service | 7 | 10-12-2016 10:13 AM |
| Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 02:39 PM |
| Valve lifter Problem !!! | Patocine | DIY / Maintenance / Service | 6 | 05-08-2012 11:09 AM |
| Adjustment to the upper shock mounting point? | Goose | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 06-07-2010 03:41 PM |
