Old 01-21-2013, 12:11 AM   #1
peckerhead
Drives: 2007 Yaris hatch
Originally Posted by UberSilver View Post
Not sure about Toyotas, but on most motorcycles the intake shims are the same thickness, and the exhaust are also matching. If the 1NZ-FE is the same way, buying a trashed engine will not help.
Hopefully this isn't the case. I'll know right away, as the lifters are marked with a number corresponding to their length. If I'm lucky, there will be at least one or two in there that will get me where I need to be with my adjustment.
peckerhead is offline   Reply With Quote
Old 01-21-2013, 12:31 AM   #2
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
They are not marked, they need to be measured.
Even IF they were marked, the numbers would be irrelevant due to wear, as you need to measure the gap, then the actual thickness of the lifter bucket, do the math for optimal gap, read the chart to see which replacement you will need.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 01-22-2013, 07:44 AM   #3
peckerhead
It doesn't really matter to me either way. It'd be easy to mic all 16 and see what I have to work with. I can get them cheap, and my car won't have to sit for a week while I wait for the dealership to get parts. If I have one tight valve, there's a 1 in 16 chance that one of my used lifters will do the job. It's not rocket science.
Old 01-22-2013, 10:46 AM   #4
Absolutely Red 12
Asshole
1 in 560 (16 X 35)
Old 01-23-2013, 05:02 PM   #5
peckerhead
1 in 560 (16 X 35)
1 in 16.
One tight valve. 16 used lifters on hand.
Old 01-23-2013, 05:13 PM   #6
Absolutely Red 12
Asshole
1 in 16.
35 different sizes.
No, the factory ones are not all the same, they are sized to fit from the 35 available, at the factory.
Old 01-27-2013, 07:12 AM   #7
yarista
Drives: 07 Yaris 3dr, 09 Yaris 4dr
Civility, Decorum Needed
Those of you commenting on this thread should please stop your squabbling. Whoever needs to adjust their valves, kindly do so and share relevant occurances during the proceedure. I started this thread in order to disseminate technical information as opposed to a bickering forum.
yarista is offline   Reply With Quote
VALVE ADJUSTMENT INTERVAL jemmah DIY / Maintenance / Service 7 10-12-2016 10:13 AM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Valve lifter Problem !!! Patocine DIY / Maintenance / Service 6 05-08-2012 11:09 AM
Adjustment to the upper shock mounting point? Goose Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-07-2010 03:41 PM
