Old 01-21-2013, 09:41 AM   #1
bronsin
bronsin's Avatar
Originally Posted by CoryM View Post
Chances are either your clutch master or slave cylinder are leaking, causing for not enough pressure to disengage the clutch. Look for, and repair any leaks and try again.
Definately a possibility a leak somewhere in the system. It sounds though like the OP isnt mechanically inclined and fears ass reaming as the hands of those who are.
I would like to help him avoid that! If he can find a leak great. Then he could point to the leak and say "Fix it!"
If he could get the car up on ramps and have a helper push the clutch in and out while he looks in the engine compartment for something moving that would go a long way. If nothing is seen to move look under the eingine for drips of fluid. That would confirm a bad component.
If no drips check in later!
Yaris 2007 remote entry doesn't open (it only closes) nicorac In Car Entertainment + Electronics (audio / video / alarm) 7 09-08-2011 11:02 AM
