Old 09-05-2011, 04:29 AM   #1
nicorac
Drives: Yaris 2007
Yaris 2007 remote entry doesn't open (it only closes)
Hello everyone, I'm experiencing a strange issue with my Yaris 2007 remote entry control; maybe someone could share some light on it.
Sorry for my bad "technical" english (hope I'm using the right terms).
The issue is this: on the remote entry control only the Lock button works, Unlock does nothing.
Details:
  • Yaris 2007
  • one key with 2 buttons embedded remote (Lock/Unlock) + transponder
  • another key with transponder only (no buttons at all)
Tests I've done:
  • all the doors Lock/Unlock using the internal switch (the one on driver door panel), so I exclude fuse or cabling problems
  • all the doors Lock/Unlock using the mechanical key (outside the driver door)
  • all the doors Lock by pressing the remote Lock button (even far away from the car) and the red LED on the key lights up, so I exclude remote battery problem and radio issues
  • pressing remote Unlock button does nothing (I hear no noise at all) BUT the red LED on the key lights up, so I exclude the button itself is broken
I tried to re-add the remote following the procedure here (http://www.yarisworld.com/forums/showthread.php?t=20865), but nothing changed.
To confirm I followed the steps correctly I also tried to remove all registered remotes; after that the remote was fully nonfunctional.
Then I re-added it, but I still have the same issue: Lock button works but Unlock not (LED key lights up with both buttons).
Hope someone could help me, I'm getting crazy
nicorac is offline   Reply With Quote
remote entry
2007 Yaris hatchback pre-wired for Cruise control? naeemishaq General Yaris / Vitz Discussion 5 11-15-2010 10:31 AM
