![]() Drives: 07 Toyota Yaris Join Date: Aug 2011
I just purchased a 2007 Yaris Hatchback 39k and I noticed that when I start the car in the morning the "Green" Coolant light will remain lit until I drive it a little bit. I checked the fluid and it was between Full and Low. I filled it with radiator fluid to the Full line and it still continues to do this. Is this normal? I didn't notice it while test driving the car and it only does it in the morning...if I use it throughout the day it doesn't light up.
Thanks in advance for any help you may be able to provide! |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Yes, it's quite normal. It's not a Low level light, purely related to temperature. It just means the engine is still cold. Red is bad of course but Green just means that the engine is still cold and needs to warm up. Drive it cautiously until the light goes off and you 'll be fine.
---Reason is we don't have an actual coolant temp guage.
Thanks for the quick response!
I felt that was the case but wanted to be sure! Thanks! |
It's alright! Welcome! If you take a quick look at the FAQ thread, you'll read some other topics many others might have been curious about.
Doing that now! Amazing site!
After learning about the DIY Cruise Control...I'll be doing that this weekend! |
I have heard also that if you have an auto-trans, you can't get into OD until after the light goes off. I have a manual so I can't say for sure. I think it goes off somewhere around 135-140 degrees. I have an ultragauge that shows temp.
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
Yes my 2007 Automatic Transmission. Will not go into 4th until the Green LED goes out. My Scanguage shows about 130 degrees F water temperature when it goes out.
The shift points are also different until the transmission warms up. |
+1 about the A/T. It's real annoying especially in the winter!
![]() Drives: 2008 toyota yaris sedan Join Date: Jan 2013
This makes me feel much better i had the same issue the day after I bought the car i was terrified i bought a lemon i have been searching to find anwsers!!
I love my yaris thanks!! |
| Tags |
| 07 yaris, coolant, coolant fluid, coolant light |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| Low engine coolant temperature indicator light -> stays on for 5 minutes... normal ? | zimso | General Yaris / Vitz Discussion | 3 | 10-19-2010 08:17 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 04:41 AM |
| Coolant Light | lifthard1 | DIY / Maintenance / Service | 6 | 07-24-2007 09:40 PM |
| Coolant Light | Cathy | DIY / Maintenance / Service | 15 | 09-04-2006 01:28 AM |
