Old 07-24-2007, 02:59 PM   #1
lifthard1
Drives: Black LB
Coolant Light
Is it normal for the coolant light to stay on longer than usual when you first start the car up while its cold.Mine stays on for about 2 min or so,I called the dealership they said it is normal .Is this true or they just
lifthard1 is offline   Reply With Quote
Old 07-24-2007, 03:02 PM   #2
steved
Yaris Rules!!
Drives: 2007 Red Yaris Liftback a/t
Yes it's normal, The colder it is outside, the longer the motor takes to warm up.
steved is offline   Reply With Quote
Old 07-24-2007, 03:04 PM   #3
lifthard1
Drives: Black LB
Thank you not use to the light staying on that long
Old 07-24-2007, 03:06 PM   #4
steved
Yaris Rules!!
you should see how long it stays on in winter time here.
Old 07-24-2007, 03:10 PM   #5
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
locked
SPONSORED BY
Old 07-24-2007, 06:43 PM   #6
joe keeney
Drives: yaris 2 door hatch
Texas 96 hot light stay on 1.30 min by the time I reach the main road its gone. Ready to roll..
joe keeney is offline   Reply With Quote
Old 07-24-2007, 08:40 PM   #7
spinejaruk
spinejaruk's Avatar
Drives: Venetian Silver Yaris
yes normal - there no temp gauge on the yaris just a light to tell you whether it is cold or hot.
If there was a gauge the needle would sit at the bottom for a couple of minutes on a cold engine and slowly move to the middle wouldn't it? - wish the yaris had one though....
spinejaruk is offline   Reply With Quote
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 06:10 PM
Coolant Light Cathy DIY / Maintenance / Service 15 09-04-2006 12:28 AM
