![]() Drives: 2009 toyota yaris S/JDM Vitz Join Date: Jan 2011
we checked the grey connector highlighted, wiggled the cord at both connection points threw the gears and nothing happened it didnt even flicker on the gear indication screen on the HUD......so i dont suspect it to be that cord....when you wiggle the gear selector it seems to locate the gears, maybe a little off of where they should be but locates them and operates normally.....i am suspecting a bad contact within the gear selector inside the car itself.... could that be plausible ?
#2 | |
The service manual indicates checking continuity on each of the switches (via the grey connector) with the shifter in each position. The gear selector inside only moves the cable - It does not feed the selector position electrically, the tranny switch does that.
| QR Code Window Stickers | nick.dollimount | Cosmetic Modifications (Exterior/Interior) | 23 | 02-25-2011 06:22 PM |
| 2010 RS Model Code?? | revolution | Cosmetic Modifications (Exterior/Interior) | 10 | 10-14-2010 05:11 AM |
| Yaris CDX 1999 P0171 error code | Davax | DIY / Maintenance / Service | 2 | 08-18-2010 07:14 PM |
| Code Scanners | smikutel | DIY / Maintenance / Service | 3 | 08-18-2010 07:09 PM |
| Check engine code 456 on brand new '09 | kameele | DIY / Maintenance / Service | 3 | 10-14-2009 11:12 PM |
