| View Poll Results: What method do you use when stopped on hills? | |||
| Use the clutch to hold the car in place |
2 | 20.00% |
| Ebrake method |
3 | 30.00% |
| Depends on the incline |
5 | 50.00% |
| What's a clutch? |
0 | 0% |
| Voters: 10. You may not vote on this poll | |||
#1 | |
also since i like to roll my car back and forth on a long red light it taught me better clutch control. to add to this, i do not believe its legal or at least recommended to use ebrake while driving. in ontario on your drivers test you are not to put your car in neutral at a red light even when holding the brake, but instead leave it in first gear and hold the clutch "just in case" you need to take off unexpectedly. IE the car behind you does not appear to be stopping. i could see ebrake as an extra un needed step in the even of an emergency. also i could see using your ebrake on a hill would decrease clutch life as from my experience i ride the clutch more when using the ebrake to control roll back on a hill. Slightly higher RPM mixed with higher friction force on clutch till i feel the car fighting forward against the ebrake and then release Also keep in mind when your ebrake is on and your not holding the foot brake your rear brake lights are not on. from my experience as a tow truck driver, getting into the routine of getting to an intersection, putting the car in neutral and pulling the ebrake is a very unsafe routine to get into Just my $0.02
#2 | |
![]() ![]() Drives: 2008 2dr Yaris Liftback Join Date: Nov 2012
Let me just say that I appreciate everyone's opinions, its just a topic I haven't heard discussed before and was wondering if there was any common variance between countries. |
#3 | |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Automatic or manual transmission | bentjazz | Fuel Economy Forum | 31 | 03-03-2011 01:52 AM |
| changing transmission oil (manual transmission) | mrb3990 | General Yaris / Vitz Discussion | 0 | 04-26-2010 11:08 AM |
| Manual vs. Auto Transmission | j996tt | General Yaris / Vitz Discussion | 30 | 02-25-2010 12:43 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
