Old 01-24-2013, 04:12 PM   #1
DJPaneno
Drives: 07 Yaris Sedan
Originally Posted by vten View Post
The retrofit source won't do the install or retrofit , although they can refer you to some installer. But expect to spend at least $200 and up for their labor.
Those mini projectors are plug and play, just make sure you choose the h4 harness .
All you have to do is bake the headlights , paint the reflector to a matte Finnish and you will be super happy with the result .
Don't necessarily need to paint the reflector bowl
Phew, well I'm going to look into seeing if I can get a buddy to help me out with a job like this. Additionally, if I go through with it, I will try and take pictures of the process for others to check out.
I'd probably end up going all in and painting the reflector bowls as well, I dig that blacked look .
So, below are the options that I have/assume I should go with. Any insight on the choices below would be helpful.
Ballasts: Morimoto 3Five (35w)
Bulbs: H1 Morimoto [FREE] vs. H1 XB35 [$30] - what is the difference between these bulbs?
Halos: Morimoto CCFL Kit $25 vs. Morimoto XB LED {White} [$50] - couldn't find anything on their site about the difference between these.
Projectors: LHD (North American Standard)
Re-Sealing Glue: Will I be needing this regardless, or only if I go through with painting the reflector bowl?
Shrouds: I'm waiting to hear back from them about which of these may be optimal for the 07 Yaris Sedan. Any thoughts?
Wiring: Relay H4/9003
Now I'm getting excited/nervous .
DJPaneno is offline   Reply With Quote
Old 01-24-2013, 07:36 PM   #2
From what I read, the XB35 are just better quality bulbs. Apparently brighter and more true to the color temp. This is up to you if you want to spend a little more (the XB35 cost 70 bucks if purchased outside the kit). I'd suggest 5000k color temp as well.
CCFL is what you generally see on BMW's (not the yellow halos). Not sure what the XB LED is. Might be brighter, I'm assuming. CCFL's are pretty bright already tho.
Yeah, it'd be nice. If you can, replace all the OEM sealant with a nice, not too thick layer of this butyl tape sealant.
The mini gattling gun should work. It's the style used in the G1 bolt on projectors (what I have) and what justdidit is using in his Prius. I'm not sure if the larger shrouds will need some modifying to fit.
See my reply in red.
projector headlights
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
CF vinyl roof, Spyder LED tails, whole car repainted 4x4Dragon Cosmetic Modifications (Exterior/Interior) 6 05-14-2012 11:39 PM
Canadians with Spyder Halo Projector Lights SeriousBlack Canada 13 11-29-2011 08:04 AM
