Old 01-24-2013, 04:12 PM   #26
DJPaneno
Drives: 07 Yaris Sedan
Originally Posted by vten View Post
The retrofit source won't do the install or retrofit , although they can refer you to some installer. But expect to spend at least $200 and up for their labor.
Those mini projectors are plug and play, just make sure you choose the h4 harness .
All you have to do is bake the headlights , paint the reflector to a matte Finnish and you will be super happy with the result .
Don't necessarily need to paint the reflector bowl
Phew, well I'm going to look into seeing if I can get a buddy to help me out with a job like this. Additionally, if I go through with it, I will try and take pictures of the process for others to check out.
I'd probably end up going all in and painting the reflector bowls as well, I dig that blacked look .
So, below are the options that I have/assume I should go with. Any insight on the choices below would be helpful.
Ballasts: Morimoto 3Five (35w)
Bulbs: H1 Morimoto [FREE] vs. H1 XB35 [$30] - what is the difference between these bulbs?
Halos: Morimoto CCFL Kit $25 vs. Morimoto XB LED {White} [$50] - couldn't find anything on their site about the difference between these.
Projectors: LHD (North American Standard)
Re-Sealing Glue: Will I be needing this regardless, or only if I go through with painting the reflector bowl?
Shrouds: I'm waiting to hear back from them about which of these may be optimal for the 07 Yaris Sedan. Any thoughts?
Wiring: Relay H4/9003
Now I'm getting excited/nervous .
DJPaneno is offline   Reply With Quote
projector headlights
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
CF vinyl roof, Spyder LED tails, whole car repainted 4x4Dragon Cosmetic Modifications (Exterior/Interior) 6 05-14-2012 11:39 PM
Canadians with Spyder Halo Projector Lights SeriousBlack Canada 13 11-29-2011 08:04 AM
