![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
I may be late to the show but...
I think there's still hp left on the table. Looks like the 108 whp is just about every bolt-on mod aside from the crank pulley, which is considered by many to be the best "bang for the buck." |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I don't believe that the pluses outweigh the minuses in that regard, as I don't think it's a good idea to remove something from an engine that provides the useful purpose of absorbing crankshaft vibrations.
If it's a horrible idea, why did Garm spend R&D building them?
#4 | |
play every day
When each cylinder chamber fires the force is transmitted through the piston down the connecting rod to the crankshaft. This force is not applied smoothly, but is a series of pushes. So when the crankshaft rotates from the cylinder pulses, the rubber connecting ring between the center of the pulley and the outer section allows the center to alternately rotate momentarily faster and slower than inertial weight of the outer section which rotates more smoothly. This helps to absorb the crank vibrations to make the engine run smoother. In high performance engines under racing conditions, this is not a consideration. So parts are engineered to meet high performance racing oriented priorities. |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
