Old 01-27-2013, 02:31 AM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by baseballfan416 View Post
I may be late to the show but...
I think there's still hp left on the table. Looks like the 108 whp is just about every bolt-on mod aside from the crank pulley, which is considered by many to be the best "bang for the buck."
I don't believe that the pluses outweigh the minuses in that regard, as I don't think it's a good idea to remove something from an engine that provides the useful purpose of absorbing crankshaft vibrations.
Old 01-27-2013, 07:55 PM   #2
baseballfan416
Drives: 2017 L 3-door
If it's a horrible idea, why did Garm spend R&D building them?
baseballfan416 is offline   Reply With Quote
Old 01-28-2013, 12:00 AM   #3
tooter
play every day
tooter's Avatar
I didn't say it's "horrible"... you said that. I only said that there are pluses and minuses for each pulley. Each Yaris owner chooses for themselves which part best meets their needs and wants.
When each cylinder chamber fires the force is transmitted through the piston down the connecting rod to the crankshaft. This force is not applied smoothly, but is a series of pushes.
So when the crankshaft rotates from the cylinder pulses, the rubber connecting ring between the center of the pulley and the outer section allows the center to alternately rotate momentarily faster and slower than inertial weight of the outer section which rotates more smoothly. This helps to absorb the crank vibrations to make the engine run smoother.
In high performance engines under racing conditions, this is not a consideration. So parts are engineered to meet high performance racing oriented priorities.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
