Old 01-29-2013, 07:07 PM   #1
Kamikaze
Kamikaze's Avatar
Drives: Yaris TS NCP13 '02
Rims size question
Hi everyone, I'm absolutely a tires/rims size newbie! be kind with me!
I use the stock tires size (185/55/R15) and wheel spacers (16mm front/20mm rear) on my '02 TS.
I'd like to buy a set of Rota RB, 15x8 4x100mm ET30, can I fit those on my car without rolling the fenders?
thank you so much!
Kamikaze is offline   Reply With Quote
Old 01-30-2013, 09:06 AM   #2
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Is your car lowered
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 02-01-2013, 02:11 PM   #3
Kamikaze
Kamikaze's Avatar
Thanks everyone for your answers!
Originally Posted by DeathBeard View Post
Is your car lowered
yes it is, TA Technix shocks+springs -40mm
Old 01-30-2013, 09:18 AM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
http://www.1010tires.com/WheelOffsetCalculator.asp
Extend 31 mm front and 27mm rear that is not bad at all but drop and tire size is gonna have a lot to do with it.
Old 01-30-2013, 11:02 AM   #5
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
thank you so much!
I think that Rota RB's are just about the most beautiful wheels made. Molto bella!
And I understand your situation, because I also was blindsided by the width/offset unknowns so I stayed closer to stock and am running 15X7 +35's and 195/65 tires with no rubbing at stock height. the front wheels are just barely under the edge of the fender so if the car was lowered, it would likely rub. This is because Rota's have a wide machined edge outside of the spokes like the old fashioned wheels used to have. Thst's why they look so distinctive.
Notice that the new style front wheel drive rims usually have none and so more easily tuck under fenders on lowered cars.
I did discover that with the +35's I needed to add 5mm spacers to allow the front wheels to clear the disc brake calipers. If you run +30's that shouldn't be an issue, because they get the wheels to position closer to the center of the vehicle by machining the inside surface that bolts onto the hubs. That's where the reduced brake clearance comes from.
Please post pics when you get them!
Old 01-31-2013, 10:13 AM   #6
Yarflana
Drives: 2008 Base Model
I just got some that look similar, not the same, and am impressed with the "better than stock, but not gangsta" look.
Yarflana is offline   Reply With Quote
Old 01-30-2013, 11:28 AM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Not a fan of those rotas. Again its all opinions. I did not have that issue with my rota gt3's and they are a +40 offset. It must be an RB only issue. Also keep in mind op has an 2002
-Derrick-
Old 01-30-2013, 12:12 PM   #8
tooter
play every day
tooter's Avatar
I think it's because the RB's are replicas of the 1960-70's era Panasport racing wheels when deep dish was the norm on RWD cars.
Enkei also made that same style in the 1980's.
Old 01-30-2013, 12:26 PM   #9
Yaristeve
Drives: 3-door hatch
They're back; they added the Compe8 to their retro line of wheels.
Old 01-30-2013, 09:14 PM   #10
tooter
play every day
tooter's Avatar
Wow... they do.
Oooh... nice!
Question about header outlet size and system diameter Shinare Performance Modifications 10 12-10-2010 09:27 PM
Best replacement tire size for stock rims? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2010 04:27 PM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
Can I use stock tires on these 15" rims? songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-18-2009 07:11 AM
Coolant Hose Size Question vasilios DIY / Maintenance / Service 2 06-27-2007 09:45 AM
