Old 01-30-2013, 07:36 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
a popular 4 cylinder factory balancing technique is to use balance shafts the are driven by the timing chain and turn in the opposite direction of the crank shaft. I'am not aware of any newer 4 cylinder engine that require external crank shaft dampening.
I'm with Why, there is no dampener pulleys on new age 4 cylinder engines.
Old 01-30-2013, 08:56 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Tell you the truth, I've never looked closely at mine to see whether or not it had any rubber in it. I believe that my 4 stroke single cylinder motorcycle has a counter rotating balancing shaft because it runs pretty smooth for a one lunger that only fires once every other rotation.
Now you guys got me all curious, so I took an inspection mirror and actually looked at my pulley. It's got a rubber dampening strip in it. Maybe the 2012's are third gen that they have them now. I also found a pic of one like mine. It looks exactly like this...
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
