![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
Hmmn. I think something got wet that wasn't supposed to; It was pretty nasty outside yesterday, all sorts of slush. My car is originally from California, so not much rust, I don't think they'd both all be broken off (and at the same time nonetheless). I'll put it on the lift at my job (I work at a dealership) and see if I can clean off and grease down those connectors.
That generally works, right? |
#2 | |
#3 | |
I did have a blown fuse a short while for my rad fan; possible electrical niggles blew something else up? |
#4 | |
I doubt that it is related to your other electrical issue, since it is just two of the four sensors, and the ABS ECU itself is alive.
ABS and Brake lights went off, but ABS remained funny acting for about 5 minutes (until it turned back on) which leads me to believe it wasn't getting proper information for the time ABS "worked".
I checked the ABS ECU connector, looks a little nasty on the outside - I'll just have to look it later; I had to run to school. |
Checked, cleaned and greased the rear sensors. Both had some blue corrosion.
Lights off, back to normal. Maybe it was just a coicidence that they both threw codes. Will defenitely keep an eye out for the next few days. |
