Old 02-04-2013, 08:34 PM   #1
yaris2010RS
yaris2010RS's Avatar
LOL, DNW my friend, i was boosted and still getting warranty ECM replacements, just makesure your convincing when you say "HOW THE FUCK COULD THAT HAVE CAUSED THAT!" its always worked for me.
Warranty issue #1, Broken Speedo/RPM cluster, Made it look like an electrical fault, toyota replaced, car had under 4,000km (i was messing with it to try to chance the cluster colour)
Warranty issue #2, Torn CV shaft Boot, I Tore it the first time i lowered my car. Car had under 10,000km, Toyota replaced boot and drivers side CV under warranty and said "sorry for this"
Warranty issue #3, side skirts were replaced, they started to seperate from the body due to the car being too low and hitting things, clearly had scrape marks, toyota replaced under 20,000km
Warranty issue #4, tranny leak on same side as replacement shaft, again car was lowered and boosted at this point, toyota replaced
Warranty issue #5, ECM got water in it and cooked, ECM got water at it because hood didnt line up perfectly after small fender bender with deer, Toyota replaced ECM under warranty
Warranty issue #6, after i replaced the engine myself, my tranny CV shaft again was leaking, they once again replaced the same seal under warranty
its actually quite hard apparently for them to legally say no to warranty claimes caused by modification unless it can be proven that without the mods that wouldnt have happened.
Old 02-13-2013, 10:04 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Wonder how that conversation would have gone when I blew 8 holes in the bock and upper oil pan from overboosting to close to 30psi
Certified Platinum Extended Warranty: worth it? Hamster DIY / Maintenance / Service 9 05-26-2012 01:23 PM
quick warranty question enobmort42 DIY / Maintenance / Service 10 08-25-2010 02:51 PM
Warranty Information for US Yaris Owners AdeJong 03 General Yaris / Vitz Discussion 4 09-19-2009 10:14 PM
Aftermarket parts and Factory Warranty in Canada? jonathanq Canada 3 07-11-2009 12:17 PM
New Yaris + warranty Question hpvampiress New YARIS Purchase Forum 9 06-29-2009 06:39 PM
