Old 02-20-2013, 01:48 AM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Hmm. I haven't looked into what all is required to go the F/IC route. Is that worth doing in the sense of accomplishing more than just allowing me to do SC while CC?
Do you know of any way to "trick" the Blitz controller into thinking that the throttle position is different than the ECU reports?
Old 02-20-2013, 06:35 AM   #2
The advantage of using a F/IC with the blitz is that the blitz fuel controller is really just intended to be used with an otherwise stock car. Adding things like an intake can make the engine run lean, so the F/IC would allow you to compensate.
There really isn't an easy way of fooling the blitz controller so that it uses the S/C with CC.
Old 02-20-2013, 02:52 PM   #3
47_MasoN_47
I probably should do that anyway. Mine throws a lean error in the ECU when I do big burnouts, which is kindof annoying and unsettling.
Old 02-20-2013, 03:20 PM   #4
Lean is definitely bad. You need to either go back to the stock airbox, or go the F/IC route.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 06:48 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
