Old 02-21-2013, 02:35 PM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Do you have an AFR meter deal thing that you would recommend installing? Or some way to easily read out the AFR? I'm not sure if you can read that straight off the ECU or not, but I have torque on my droid that can read a lot of stuff off of there.
Old 02-21-2013, 02:39 PM   #2
I use my YarGauge to display it in realtime (I use the Toyota enhanced diagnostics protocol, so I can read it faster than a standard OBDII device can). Torque may be able to display it. It won't be realtime, but should at least give you a decent idea as to how lean you are going.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 06:48 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
