#19 |
Maybe. You might have a slight leak that seals up when things swell with heat. With the switch in the "low" position, I see boost pulling out of my driveway.
#20 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Here's a little video of how it's behaving.
http://www.youtube.com/watch?v=c-wgrJeqEMc The gauges are (left to right) boost, oil pressure, oil temperature.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#21 |
The other thing it may be, besides the seal leaking, is the belt slipping.
#22 |
Hmm. I need some way to put a camera in the engine bay so I can see what's going on in there while the engine is under load. The belt has been letting one or two little squeaks upon startup lately, but it's been behaving like this ever since I've had boost (this is not the same belt I started with).
Also, checked the AFR and it seems to hover around the 14.7 range even when under pretty heavy throttle. Is that a dangerous level to run with S/C?
#23 | |
For the cold boost issue, I would tighten the belt a few more turns of the bolt and see if that does it. My experience is that if the belt squeals for a second on start-up that it definitely will slip when the S/C engages.
#24 |
Blarg. I emailed Garm about it, seems like he said that he had a means to tune that Blitz controller thing to compensate for being lean.
I'll try tightening the belt and see what happens. For good measure I'll go ahead and make sure all the manifold bolts are tight too.
#25 | |
#26 |
Hmm... what injectors would you recommend? Also would that be cheaper than going the F/IC route? I mean I still want to do it at some point, but I can't afford to drop another g right now.
#27 |
^ 1ZZ injectors are the next size up.
#28 |
The 1ZZ injectors can be picked up used for around $100 for a set.
#29 |
Ok cool, well I've got a set of 1zz from a Celica coming. I really wish I had thought/known about this earlier... my fiance's mom totaled her Corolla a couple months ago. I probably could have just stolen the injectors from that and stuck my Yaris ones back in it without anyone knowing. It wouldn't run anyway. Would have saved me a little money, lol.
So, if I drop these 1zz in there will the ECU not be able to keep the AFR at that 14 range?
#30 | |
#31 |
Nice. I really appreciate all the help you've been over the years.
BTW do you have any other suggestions of stuff I should do to help the car out now that it's boosted? I switched to synthetic oil (mobil 1) when I went boost already. I've got a decent amount of other mods done. I just updated my garage so that everything's up to date if you want to look that over. I do plan on going F/IC at some point.
#32 |
This whole "your engine might be completely fubar" thing doesn't make me real happy.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 Last edited by 47_MasoN_47; 02-22-2013 at 01:19 PM. Reason: grammar |
#33 | |
#34 |
Ok.
I haven't measured my AFR at WOT. Is that the only position where it really matters? I was just thinking that it seems like under normal conditions the ECU would probably maintain that 14.7 AFR even with the stock airbox during normal conditions. It would make sense that under WOT I could be lean (since that's what I was doing when I got the lean code that one time) but for the most part it seems like it would be ok where it is? Just trying to clarify. The car seems to be running fine. I turned the boost off for the time being (jesus these cars are slow without boost, I forgot what that's even like) and am going to get my fiance to help me with the compression test tonight.
#35 | |
#36 |
Hmm ok. I think I'll try another run today and see if it behaves the same way as yours.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Rostra 250-1731 cruise control kit for Yaris | PeetYaris | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 06-26-2011 06:48 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
